need help..
Old Jan 29, 2010 | 10:02 PM
robby_angala's Avatar
robby_angala
Default need help..
my steering wheel just recently keeps on shaking when ever I hit the 100 km mark. I took my Z to 3 different alignment shop already but nothing happened. has any of the members here experience this problem?
Old Jan 29, 2010 | 10:16 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jan 29, 2010 | 10:23 PM
SatchScream's Avatar
SatchScream
^ What he said.
More likely to find help that way.
Old Jan 30, 2010 | 12:22 AM
$LiK RiK's Avatar
$LiK RiK
have u hit a pothole resently...u might have bent or broken something an it not visible...make the alignment shop get it right which should of been done b 4 u paid....
Old Jan 30, 2010 | 07:11 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Bad alignment, worn-out tires, out-of-balance tires, bent or loose suspension components. Could be quite a few different things. Take to a shop that knows cars, not just tires and alignments.
I've had the same thing happen at about the same speed when driving on badly worn tires on different cars. Could be as simple as getting new tires.
Old Jan 30, 2010 | 10:11 PM
shiftdrift06's Avatar
shiftdrift06
+1 bought a pair of used tires once. Had plenty of thread left, but the non visible belts on inner side were broke. Caused my car to shake at certain speeds.
Also, have your tire balanced, maybe simple as a weight falling off.
TOPLESSFAIRLADY
Apr 27, 2005 07:19 PM
Static
Dec 25, 2003 03:08 PM
03 Z for ME
Cleaning & Detailing
May 10, 2003 07:37 PM
