Noise at Start up :(
Old Feb 5, 2010 | 11:44 AM
Julias350z's Avatar
Julias350z
Default Noise at Start up :(
Ok this is pretty embarrassing But whenever I start my Z and the engine is cold (been sitting for more than 30 minutes) it has this terrible rocking clanking noise (I have a recording of it but don't know how to put it on lol ) So I guess if I can figure out how to put the recording of the sound on here that might be the best of help....and then we can go from there...
p.s. Hope this in the correct place?? I couldn't really find a specific place for my problem....
Oh my gosh it sounds so terrible...I'm tempted to not even put it on here lol......and when I was trying to get the noise it started with a squeal!! Ahhh So just skip the middle part maybe it's to terrible HELP!
http://www.youtube.com/watch?v=ft8oI9cQn_U
Old Feb 5, 2010 | 11:47 AM
calin's Avatar
calin
+1
Old Feb 5, 2010 | 11:51 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Yup, your in the correct area....just get that recording up so we can help you out.
Julias350z's Avatar
Julias350z
Calin you're suppose to help!!
Old Feb 5, 2010 | 12:29 PM
diablox1's Avatar
diablox1
easiest way, most straightforward way: take a digital camera (w/video recording capabilities, of course), record the sound, create a youtube or photobucket account, upload the file to the chosen hosting site, post link to the video here.
Old Feb 5, 2010 | 01:12 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
most likely piston slap on crank up mine does it with thinner synthetic oil. but without the audio i could never tell you what it is lol.
Old Feb 5, 2010 | 01:58 PM
Julias350z's Avatar
Julias350z
Ok added the sound
Old Feb 5, 2010 | 02:01 PM
TheFarmer's Avatar
TheFarmer
How's your oil level? The clacking at startup sounds like it had to build up oil pressure before the noise went away. The squeal is one of your drive belts.
Old Feb 5, 2010 | 02:02 PM
Julias350z's Avatar
Julias350z
Oh I used to have the squealing but put soap on it....it worked and now it just did it today.....first time in a couple months. But the belts were just replaced when it started doing it and they were not too lose or too tight.
Old Feb 5, 2010 | 02:03 PM
Julias350z's Avatar
Julias350z
It has done it since I got the Z a few months ago.....and I had the oil changed and levels are good.
Old Feb 5, 2010 | 02:04 PM
TheFarmer's Avatar
TheFarmer
Try tightening it just a bit more. It may seem excessive but the belt is obviously still slipping. What brand of belts did you put on?
Old Feb 5, 2010 | 02:12 PM
Julias350z's Avatar
Julias350z
I got the belts from Oreilly...they were called Micro-V Belts....
Old Feb 5, 2010 | 02:15 PM
Nastynate612's Avatar
Nastynate612
I had the same problem in my 02 wrx and replaced all the belts i could find, and it would go away for a couple days then come back. I finally got fed up with it and asked a buddy to look at it, we found out it was the A/C compressor. That fixed the problem.
Old Feb 5, 2010 | 02:16 PM
TheFarmer's Avatar
TheFarmer
Micro V's are made by Gates, decent stuff. I would definitely try tightening them up just a bit more and see what happens.
As for the startup noise, it sounds like a oil pressure issue (maybe tensioner/chain slack as well?). I know my Z makes a similar noise after it's been sitting for weeks or months (I don't drive it often) but if I drive it everyday it doesn't do it. I'm sure someone with more noise knowledge will chime in
Old Feb 5, 2010 | 02:25 PM
SniperHunter's Avatar
SniperHunter
Tighten up the belts a bit more for the squeal.
Old Feb 5, 2010 | 02:27 PM
SniperHunter
Btw: I'm surprised for someone who knew how to edit three clips into one, you didn't know how to upload or post a video.
Old Feb 5, 2010 | 02:32 PM
Julias350z's Avatar
Julias350z
Well I originally recorded it with my iPhone (first time using that to record) and that format was not recognized by anything so I used my camera to get the sounds there....and I am a pro at video making lol not trying to brag....
Old Feb 5, 2010 | 03:02 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I concur with above posts and your belts, but regarding some of the other noise. Do you push the clutch in when you start the engine? If you don't, do.
Old Feb 5, 2010 | 03:13 PM
screener's Avatar
screener
Although this is not a 350z he is correct to not over look the A/C comp. and such. If this problem has not gone away after doing all the common stuff, you have more there then. I would have a tech inspect, you possibly have a bad part in the drive belt path.
P.S I had the exact samething happen with my wrx nastynate.
Old Feb 5, 2010 | 03:25 PM
raycs7's Avatar
raycs7
I have a momentary knock when I start up.
it has been that way for 30K.
Mine may be oil pressure to the tensioner.
I have my daughter using it now but it has not failed.
