Replacing Window Trim?
Old Feb 11, 2010 | 10:46 AM
AML225's Avatar
AML225
Default Replacing Window Trim?
So this happened the other day. Not a big deal but it pisses me off. The plastic tab that screws this part down broke so it just stays popped up like this. When I try and push it down it's actually quite difficult as this thing is under a lot of tension. Has this happened to anyone?
I'll probably just go to nissan and replace it, any idea how much? Part number?
Old Feb 11, 2010 | 11:14 AM
dleariousz's Avatar
dleariousz
Nope havent ever seen that happen.
Old Feb 11, 2010 | 11:35 AM
raycs7's Avatar
raycs7
I have that issue.. I plan to superglue first
Old Feb 11, 2010 | 12:20 PM
ericjackson's Avatar
ericjackson
when i got my z used mine was glued. the stealership actually did it. hah. i broke it again, and replaced. it. now mine is broken AGAIN. its just a cheap piece of plastic and keeps breaking. im assuming from catching the door on my pants or something. its not a cheap part either
jv350z's Avatar
jv350z
I had the same problem. Superglue didn't work. Double sided tape didn't work....
Get it fixed right.
Order Information:
Belt w'strip Left 1 $57.06
Took 3 minutes to install. All good now.
Old Feb 12, 2010 | 06:06 AM
dleariousz's Avatar
dleariousz
Damn, what year Z's do you all have?
Old Feb 12, 2010 | 08:39 AM
raycs7's Avatar
raycs7
I got my 03 with this broken.
My other cars are OK.
Old Feb 12, 2010 | 10:31 AM
H22toVQ's Avatar
H22toVQ
Mine was like $70. Easy to install and superglue was a temporary fix. I just left it until I was entering in a show and finally replaced it.
Old Feb 15, 2010 | 02:49 PM
RickBob's Avatar
RickBob
WTF!!! this happened to my 08 Z also!!!! on the F'n driver side!! i wish they'd recall that ****!
Old Feb 15, 2010 | 05:56 PM
Octogoogles's Avatar
Octogoogles
Yup happened to me. 45 bucks for a new one...
Old Sep 20, 2011 | 07:18 PM
Jake8267's Avatar
Jake8267
Default Drivers side window trim
Hey guys thanks for taking a look at this thread...im not 100% sure if this is where it belongs, but im hoping so.
I digress, My drivers side window trim has a clip, that basically holds it on/down onto the door from the inside above the door handle...its broken there fore causing my trim to look bent, sitting about one half inch above where it should...I looked all over online for the clip, and couldn't find it...Im hoping someone here has the answer. It cant be a very rare occurance, because about 50% of the z owners i contact in person are having the same issue....
Many thanks
Old Sep 20, 2011 | 08:21 PM
ZSilverBullet28's Avatar
ZSilverBullet28
Pictures would be a huge help..
Old Sep 20, 2011 | 09:35 PM
jv350z's Avatar
jv350z
Maybe this:
https://my350z.com/forum/exterior-an...rior-trim.html
If so, I had this problem. it was an easy fix/install.
Old Sep 21, 2011 | 08:38 AM
Jake8267's Avatar
Jake8267
Originally Posted by jv350z
Maybe this:
precisely. thanks
Old Sep 21, 2011 | 08:40 AM
Jake8267's Avatar
Jake8267
there has got to be a cheaper alternative to fix this, and I would think there has to be a better constructed way as well. im going to put my thinking cap on, and see what I can come up with.
Old Sep 21, 2011 | 09:29 AM
Jake8267's Avatar
Jake8267
http://www.nissanpartszone.com/Page_...ponentsIndex=7
I think ive found the part, although im not 100% sure exactly which one it is.
Old Sep 21, 2011 | 09:32 AM
Jake8267's Avatar
Jake8267
Old Sep 21, 2011 | 09:43 AM
green_bread's Avatar
green_bread
Good luck finding the replacement clips... I know how annoying an issue like that can be.
It seems like pretty much every plastic clip in the door is pretty weak. Like, I looked at one the wrong way when I was replacing my window motor and the ****er broke.
Old Sep 21, 2011 | 11:11 AM
techtalk's Avatar
techtalk
I may be off here but can't you simply replace the grommet/screw that adheres the piece to the door assembly?
**diagram courtesy of nissanpartszone.com; all rights reserved
The screw in question is part code #80820E in the diagram above. If this is the screw that you guys are referring to then it's seriously an 82 cent part
Old Sep 21, 2011 | 12:15 PM
Jake8267's Avatar
Jake8267
exactly my thought, i found the same page earlier today and posted it in my other thread. Im not sure if its just the screw in question as much as it is clip that it holds...
