Need AEM Wideband Help
Old Apr 14, 2010 | 06:57 PM
hwcustoms's Avatar
hwcustoms
Default Need AEM Wideband Help
I tried to do a search but didn't see anyone with this problem so I thought I'd ask.
When I turn my key my wideband comes on as normal and goes through it's cycle. Then it goes to 14.8 and stays there. This is even before the car starts. Then I turn the car on and it stays at 14.8 and the light strip never moves.
I checked all the connections and the o2 and everything looks to be in place.
So is my o2 fried? Is the gauge bad?
I am always greatful for the insight......
Old Apr 14, 2010 | 08:28 PM
tylerxfire's Avatar
tylerxfire
are you sure you hooked the wires up correct and that it is plugged into the harness correct and fully? check over the work to make sure it is all correct..
if so..with the gauge on and the 02 out of the exhaust pour a little gas on the o2 or spray some starter fluid on the o2 it should go rich if everything is hooked up correct and if doesnt then there is a problem with the unit or the o2, id say the O2...
Old Apr 14, 2010 | 08:43 PM
hwcustoms's Avatar
hwcustoms
^ thx for the response. I am 99.9% sure all the conections are fine. The gauge starts up as normal, just stays on 14.8. I will try the gas and see if that works. If not do I need to buy a whole new setup or can I change the o2 out?
Old Apr 15, 2010 | 06:45 AM
tylerxfire's Avatar
tylerxfire
where did you purchase and how long ago? should have warranty to call them and see what they say wherever it was..I would say you can replace just the o2 sensor but i first would try to get it under warranty if u have that..
U will have to get the o2 for that setup with the right connection too and not just any random o2
Old Apr 15, 2010 | 08:46 AM
hwcustoms's Avatar
hwcustoms
The o2 looked pretty good and it cleaned up well. When you unplug the o2 from the gauge still says 14.8. I am going to go all through the connections again and see if I can find anything.
350Shadow
Sep 22, 2015 08:30 AM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
