Raining....in my car
Old Apr 25, 2010 | 09:09 PM
bno1616's Avatar
bno1616
Default Raining....in my car
Every time it rains my passengers side floor in the back, behind the seat, floods up with water. I don't really see any leaking coming from the door or the window though. Maybe it is coming up from under the car? Just wondering if anyone has experienced this problem before or have any suggestions where to take it to get fixed?
Thanks,
Lauren
Old Apr 25, 2010 | 09:12 PM
Gibbs's Avatar
Gibbs
Know it all
Is your car a roadster or a coupe?
Old Apr 25, 2010 | 09:14 PM
bno1616's Avatar
bno1616
coupe
Old Apr 26, 2010 | 12:09 AM
MOB's Avatar
MOB
Weird, I had it on my other car but there was a cut on the door seal I just fixed it for $10. Its weird that its on your coupe. Ya go get it checked out ASAP. It cant be from under your car unless your driving over puddles? or is it every time it rains while its parked? Post up some pics of your car, show where the water is at and your passenger side door.
Old Apr 26, 2010 | 03:27 AM
Troubleshooting water leaks is difficult. If you have ever owned a boat you know that water can enter one place. move UP hill, and you discover it at another location.
Tape some paper towels from a roll inside the car.
Wash car.
Look for water on the towels. This may give you an idea where water is entering the car.
Old Apr 26, 2010 | 06:05 AM
duro78's Avatar
duro78
did you have any body work or windows replaced recently?
Old Apr 26, 2010 | 08:36 AM
Gibbs's Avatar
Gibbs
Know it all
A good way to diagnose where it's it's coming from is to get in the car windows up, and have some body spray it with a water hose, and you look for leaks/wet spots, and go from there. However if you still have a warranty on the car take it to Nissan.
Old Apr 26, 2010 | 06:31 PM
_Donovan_'s Avatar
_Donovan_
I had the same problem. Look at the window seal around the outside near the bottom right on that side. It is kind of shitty and overlaps, but sometimes it gets pulled up and doesn;t seal anymore.
Old Apr 26, 2010 | 06:32 PM
_Donovan_'s Avatar
_Donovan_
Wow, I guess I should not drunken post, I see your problem is near the rear, I thought it said in the front. IDK, good luck.
Old Apr 27, 2010 | 03:13 PM
Mike@Blackline's Avatar
Mike@Blackline
Wash car.
how does it feel OP to have the first serious reply from davidv in 35K+ posts
one of my Zs would leak from the triangle at the front of the door. it was pretty obviously visually so it sounds like thats not your place. gl
Old Apr 27, 2010 | 06:35 PM
carlili4190's Avatar
carlili4190
Mine had a slight leak by the tweeters...
etkms
Jun 19, 2022 06:30 PM
StreetStandard
Videos
Feb 4, 2016 09:44 AM
