window switch problem
Old Jul 5, 2010 | 08:14 AM
uhlo666's Avatar
uhlo666
Default window switch problem
Hello, I had an issue with drivers side window few weeks ago, therefore I changed the window motor and now it works ok. In the last 3 days I have an issue with passenger's window, but there are different problems. The window stayed at the lowest position, switch for window didn't work neither from driver's door, nor from passengers door. Also central lock switch on the driver's door didn't work when I pushed it at that time and also when I closed driver's door, the window didn't roll up 1cm or so (to get on max position). But when I tried to close the driver's window with the switch, it worked. Also central lock with keys is working. At night when it was colder it worked as it should. Also passenger's door is closing and also the lock button on driver's door worked.Anyone had the same problem?Or shall I change the switch unit on the driver's door?
Thanks
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
