heeeeeeelp
Old Jul 18, 2010 | 12:15 PM
angel700's Avatar
angel700
Default heeeeeeelp
this is the situation, i had a p0011 code, i changed the camshaft position sensor bank1, and sitll receiving the p0011 code...
the car is smooth as a kitten..
still don't know what the problem is....
Old Jul 18, 2010 | 12:27 PM
BonesZ33's Avatar
BonesZ33
pull the spark plugs, check if there is oil on them.
Also check the camshaft connector, and follow the wiring to the harness. if all else fails .. worst case it could be a loose timing chain.. how many miles do you have?
Old Jul 18, 2010 | 02:10 PM
angel700's Avatar
angel700
42k ish
Old Jul 18, 2010 | 03:21 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Jul 19, 2010 | 08:12 PM
angel700's Avatar
angel700
Squeaking brakes
instead of
Help
ok, thanks for the suggestion.
angel700
Aug 24, 2010 01:59 PM
