Crank position sensor going out?
Old Nov 27, 2010 | 09:55 PM
STL 350Z's Avatar
STL 350Z
Default Crank position sensor going out?
So last night it started going into limp mode and would not go above 2500 rpm. Tonight it had a rough time starting and idled around 2000 rpm between gear changes once warmed up. I have no check engine light but that doesn't mean there isn't a code so I am going to Advance tomorrow to see if they can pull some codes. Currently I am thinking crank position sensor?
What do you all think? It's a stock 2005 base model, 6 spd and has 94k miles on it...
Old Nov 27, 2010 | 10:00 PM
surfcity40's Avatar
surfcity40
no disrespect but this has been asked and answered.
Old Nov 27, 2010 | 10:58 PM
STL 350Z's Avatar
STL 350Z
Sorry but these 15 results didn't help to much.
https://my350z.com/forum/search.php?searchid=12698210
I'll just see if I have any codes tomorrow and go from there. Thanks...
Old Nov 28, 2010 | 10:34 AM
STL 350Z's Avatar
STL 350Z
Code P1271 mass air... I cleaned it with CRC MAF cleaner and I'm gonna go from there.
Old Nov 28, 2010 | 06:59 PM
mugen727's Avatar
mugen727
I have a 05 6speed and my crank position sensor went berserk at 40k miles. Everytime I gas'd the throttle the car would jolt crazily. I brought it to my local shop and changed out the sensor with a new OEM one and haven't had a problem since. Hope that helps?
Old Nov 29, 2010 | 09:32 PM
STL 350Z's Avatar
STL 350Z
Thanks man! I cleaned the MAF and it's back to running great now except for the passenger side window motor crapped out... but hey that's a known issue with owning a Z LOL!
2ndchanceZ
Oct 26, 2015 08:03 PM
Depravity
Oct 1, 2015 04:49 PM
