Console around shifter removal
Old Nov 24, 2003 | 03:26 AM
jmark's Avatar
jmark
Default Console around shifter removal
What's the easiest way to remove the console around the MT off without scaring it up? Want to install my NISMO GT shift ****.
Old Nov 24, 2003 | 06:27 AM
Audito350Z's Avatar
Audito350Z
I don't belive you need to remove the console to install the shift ****.
The OEM shift know is on very thightly... I've seen a few posts of people who wrap a towel around the lower portion of the shift **** and use a Channel Lock pliers over the towel to twist it off.
Hope that helps.
PeteH
Old Nov 24, 2003 | 09:52 AM
lowrider's Avatar
lowrider
To avoid transmission damage, it's also recommended to pop up the trim ring around the boot, and vise grip the shifter rod, before you turn the ****.
Lou
Old Nov 24, 2003 | 10:06 AM
RedHerring2's Avatar
RedHerring2
I have to replace that console piece so knowing if anyone has removed the boot with the jillion screws in the mount would be helpful.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
