driver seat problem plz help
Old Apr 9, 2011 | 06:10 AM
Z33TUNER's Avatar
Z33TUNER
Default driver seat problem plz help
Hey guys, I have a little problem with my driver seat, I was wondering if any of you have the same problem or even better know how to fix it.
Well first I have the black leather seat that comes with power moving.
The switch that moves the seat front and back works 100%. But the other switch that supposes to move the back of the seat front and back is not working.
I moved the back of the seat all the way to the back so I can wash my car, but when I tried to put the back of the seat forward to sit in, it won’t come back
So now my seat it stuck all the way back and it feel like I’m laying down while driving.
Can anyone plz help.
Old Apr 9, 2011 | 10:01 AM
350sexZ's Avatar
350sexZ
I have the same problem the reclining portion from time to time doesn't work. The I got a paper clip and put it in side the little space between the switch and the casing and put the paper clip under the switch and just kept going around in there few time too see if it could clear anything stuck under the switch and after about 2 to 3 minutes are messing with it it finally started to work. Now I keep a paper clip in my car. Lol
Old Apr 9, 2011 | 11:59 AM
Mcutali's Avatar
Mcutali
Default 04
bought the z i currently own now 4 years ago, 30k on the clock.
sometimes driver seat wouldnt go back and forth, and one day it cut out.. warranty and 1200$ claimed to the warranty company..after my 100$ deductible all set! good luck man.
Old Apr 9, 2011 | 02:34 PM
youngflyer's Avatar
youngflyer
i have the same issue slightly, mine will go up and down but takes some playing around with!
Old Apr 9, 2011 | 04:23 PM
Waiz's Avatar
Waiz
Don't hold down the button, just press it and release it a few times and it might be able to move.
That worked once for me when the seat was stuck in the full cholo-lean position.
Old Apr 10, 2011 | 04:25 PM
Z33TUNER's Avatar
Z33TUNER
my good friend said the switch short circuit, does that make sense?
Old Apr 12, 2011 | 09:11 AM
e46330i's Avatar
e46330i
hopefully your motor is still okay. that's an expensive job to do :/
Uriyo_
Sep 8, 2021 08:46 AM
