Clutch wont disengage
Old Apr 1, 2014 | 06:53 PM
npr350z's Avatar
npr350z
this is what happens when you shift gears unprotected, then your clutch and tranny get engaged... im sorry.
you probably have air in it, atleast tranny fluid doesnt smell near as bad as brake fluid...well transmission fluid atleast
Old Apr 2, 2014 | 04:27 AM
Syner's Avatar
Syner
Originally Posted by dailydriver350Z
Master was not bench bled before install. I did a gravity bleed for a while after install. Do you think I could have messed it up?
I tried a new test today... Let the shifter rest against 1st and pump the **** out of the pedal... slid in after i beat the crap outta the pedal
I'm leaning toward the master as well now
I'm thinking master as well. When mine went to sh*t, I had to pump it a few times.
Old Apr 4, 2014 | 04:54 AM
dailydriver350Z's Avatar
dailydriver350Z
Changed everything! New clutch master, flex line and slave... problem is still there!!! Help!
Old Apr 4, 2014 | 05:42 AM
dailydriver350Z
Hey NPR - what do you mean by engaged? could you please explain exactly what you mean?
Old Apr 6, 2014 | 09:27 AM
dailydriver350Z
Talked to my trans guy finally! He says the synchros are messing up when warm. I'm going to disassemble the clutch and inspect it to see if there is any visual damage when I put my old transmission back in. He is going to rebuild it on the side and hopefully I'll have a fully operational car soon! Anybody has any thoughts, questions or similar situations hit me up and I'll do whatever I can to help!
Have a great one guys!
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
