HELP your fellow 350z owner!!
Old Jul 29, 2011 | 10:52 AM
CSithy's Avatar
CSithy
Default HELP your fellow 350z owner!!
So basically here's the story:
I have a 2003 350z Touring. About a month ago, I was driving it and the car started shaking. I was at a light and it was idling really rough, and it literally sounded like a muscle car..
Anyway, the ecu reader threw out the codes p0300 and p1805. I know p0300 is a random misfire. I checked the spark in each coil and 2 of the 6 were not sparking at all. I replaced the 2 coils, and the car was running fine... and then they blew up the next day. After replacing those AGAIN while trying to see what was wrong with it, the car blew 4 coils.
I read some other forum posts about the same problem and NO ONE has had it solved yet.. Others say check the spark plugs, ignition coils, bad gas, vacuum leak and I've tried it all at this point.
HELP!!
Old Jul 29, 2011 | 11:01 AM
winchman's Avatar
winchman
Sounds like a grounding problem to me.
Old Jul 29, 2011 | 11:10 AM
CSithy's Avatar
CSithy
Checking all the wires/cables was definitely going to be my next move.. thanks, ill keep updating.
Old Jul 29, 2011 | 01:45 PM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Workshop12
Mar 23, 2020 01:45 PM
chief3630
Feb 29, 2016 02:54 PM
SonnyWu
Nov 24, 2015 08:19 PM
davidm350
Oct 31, 2015 02:28 PM
416blueZ
Sep 25, 2015 10:00 AM
