Suspension Squeaking
Old Sep 14, 2011 | 08:05 AM
KRM5124's Avatar
KRM5124
Default Suspension Squeaking
Okay so left Tire squeaks when I turn to the left, even slightly but when going straight or to the right makes no noise.
From what Ive found an alignment issue seems to be the most common cause of this.
So basically my question is does everyone agree this is alignment or is there something else I should try before dishing out the cash for an alignment?
Thanks for any responses
Old Sep 14, 2011 | 08:40 AM
DavesZ#3's Avatar
DavesZ#3
I've never heard of a tire squeeking before. Brakes, wheel bearings or other suspension components maybe.
Even if it was the tire making noise, alignment wouldn't matter. An alignment is set for your car driving straight ahead, not when making turns.
How old/ how many miles on our Z? When was it last aligned?
Old Sep 14, 2011 | 09:58 AM
KRM5124's Avatar
KRM5124
Sorry what meant by tire squeaking is the noise is coming from the left front tire area, but Im not sure exactly where it is coming from.
It's a 2005 with 62k, and Im not sure of when it was last aligned as I bought it in July.
The best way I can describe the squeak or squeal is a pattern of squeal..nothing..squeal..nothing etc.. the faster I go the faster the pattern and vice versa, but only when turning to the left even the slightest.
Old Sep 14, 2011 | 11:44 AM
beezee's Avatar
beezee
Are you lowered?
Old Sep 14, 2011 | 11:46 AM
KRM5124's Avatar
KRM5124
Are you lowered?
No.
Old Sep 14, 2011 | 12:21 PM
Barnabas's Avatar
Barnabas
National Z Club President
wheel bearing or bushings most likely
Old Sep 14, 2011 | 12:40 PM
KRM5124's Avatar
KRM5124
Ill try cleaning my bearing this weekend and see if that is it
Old Sep 14, 2011 | 04:29 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Cleaning the bearing won't do any good. Lift the car up and place it on a jack stand. Grip the tire at the top and bottom and try to rock it in/out. If it moves, the wheel bearing is bad.
Old Sep 15, 2011 | 10:49 AM
KRM5124's Avatar
KRM5124
alright Ill try that tonight when I get home from work
Thanks
Old Sep 15, 2011 | 04:03 PM
KRM5124's Avatar
KRM5124
Okay so I jacked the car up and rocked the tire, I got about 1/4-1/2 inch of movement, I also did it on the opposite side (the one Not making noise) and got about the same movement. Since both sides are about the same, and correct me if I'm wrong here, I'm guessing my squeak if coming from another source.
So any other ideas?
350Z_Al
Oct 29, 2020 07:44 PM
pr_350z
Oct 1, 2015 05:03 PM
