Rev Problem
Old Jan 7, 2012 | 10:57 AM
Tomek350Z's Avatar
Tomek350Z
Default Rev Problem
I have a strange problem that hopefully someone could lead me in the right direction. When in any gear coming up to a stop, I put the clutch in and the car in neutral to coast, my revs kinda bounce around. Once I put it into neutral, th revs drop to a thousand and then kick back up and stay around a thousand five hundred for a couple seconds, then slowly drop down to idle. anyone have a similar problem, no codes, no driveability issues, it just pisses me off, and from what i remember my car has never done this, because normally when you put in the clutch the revs should drop instantly down to idle.....
Old Jan 7, 2012 | 02:01 PM
Cass007's Avatar
Cass007
Try cleaning and resetting your throttle body.
Has the car been yours since new? Ever been osirus or uprev tuned.
Old Jan 7, 2012 | 03:06 PM
Tomek350Z's Avatar
Tomek350Z
yes the car has always been mine, no aftermarket tune. as for the reset, i did the idle air and throttle body reset via FSM and didnt help. Then I unhooked the battery and left it for a day. Still did not help
Old Jan 17, 2012 | 02:57 PM
Tomek350Z's Avatar
Tomek350Z
anyone got other suggestions
Old Jan 17, 2012 | 03:32 PM
djtomski's Avatar
djtomski
I had similar issues ('05 non-revup motor) but only after I had a plenum spacer installed. Mine also idled high. Got it taken care of at the dealer. I guess they put in new parameters or rpm range for it to idle, something like that. Possibly could be the same fix? If you have a warranty still I suggest stopping at the dealer to get it looked at, otherwise it'll cost like $140.
Uriyo_
Sep 8, 2021 08:46 AM
