Reverse, license plate, and emergency lights not working
Old May 5, 2012 | 05:17 AM
stoffius's Avatar
stoffius
Default Reverse, license plate, and emergency lights not working
Fuse appears to be okay as are the bulbs themselves.
Reverse lights haven't worked since I bought the car years ago. Yesterday I decided to replace the bulbs only to find out they're fine. I check fuse #71 at the EPDM and it's fine. I replace it with the spare 10A and no difference. Now I notice that the emergency flashers no longer work (they did last time I hit them months ago) nor do the license plate lights come on. All other lights work correctly.
Is it possible the 'back up' relay has gone bad? Is there anything else I should be checking?
Searched forums and cannot find anything relevant. Closest thing is that the reverse sensor on the MT may be bad but would that also cause the other lights to go out?
Any help greatly appreciated.
Old May 5, 2012 | 01:43 PM
jv350z's Avatar
jv350z
can you open the hatch with the button by the license plate (not via the fob/remote) ? If not, I suspect the rear harness / connector may be disconnected.
Old May 6, 2012 | 10:10 AM
stoffius's Avatar
stoffius
I am able to open the hatch with the button in between the bulbs.
Old May 8, 2012 | 08:42 AM
stoffius's Avatar
stoffius
Any idea's?
Took it to dealer yesterday to ask around but nobody had an answer so really hoping someone on here can give some suggestions so I can continue trouble-shooting.
Old May 11, 2012 | 06:37 AM
stoffius's Avatar
stoffius
Anyone think it could be an EPDM issue?
davidm350
Oct 31, 2015 02:28 PM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
