cleaning injen dual cai
Old May 30, 2012 | 10:29 PM
foshau23's Avatar
foshau23
Default cleaning injen dual cai
hey guys,
those of you who have an injen dual cai, or any other similar setup.. what have you found to be the best way to clean and maintain the filters? thanks
Old May 30, 2012 | 11:26 PM
This has been a stimulating conversation. Drop by again soon.
Old May 31, 2012 | 12:31 AM
bluelineshooter's Avatar
bluelineshooter
Buy an air cleaner kit. It should come with two bottles. One is the actual cleaner and one is the lubrication oil you apply before reinstalling. Directions come with in but basically you spray your air filter (I'm assuming you have two cones) with the cleaner and let it sit for about ten minutes and then rinse it well with low pressure water. You'll see that the water running from your filter will be very dark and yucky. Then you must let the filter dry completely before applying the oil (the other bottle in the package) evenly and reinstalling the filters. I buy K&N intake cleaner. Hope that helps.
Old May 31, 2012 | 01:22 AM
Suwaidi's Avatar
Suwaidi
http://www.crackaddict.com/~flynn/ho...ncai.howto.htm - Scroll to the bottom.
Steps:
a) Get a K&N Filter Cleaning Kit (sold at most Autozones and NAPAs)
b) Rinse first from inside of the filter using a stream of water
c) Use the cleaning spray and let sit for 10 minutes
d) Rinse after 10 minutes, and allow to air dry
e) Lightly oil the filter. Wait 5-10 minutes for the oil to absorb
You can check the DIY forum for how to reach the air filters if you haven't before.
Old May 31, 2012 | 05:07 AM
R350Zz33's Avatar
R350Zz33
you wanna know if theres a better way way to to to the filters im guessing
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
_bit
Oct 2, 2015 07:49 AM
