03Z Driver’s Window Working Intermittently
Old Jun 26, 2012 | 06:03 AM
EyeOutThere's Avatar
EyeOutThere
Default 03Z Driver’s Window Working Intermittently
The driver’s side window on my Z stops working intermittently. It also does not lower/raise that little but when the door is opened/closed.
I don’t think it is a fuse because the passenger side works fine.
Are there any schematics of the window circuit that could help me debug this?
I am hoping it isn’t the motor itself.
Thanks!
Old Jun 26, 2012 | 07:20 AM
cubs4worldseris's Avatar
cubs4worldseris
You can pull the fuse and see it if is blown, but if the window is working intermittently it will not be the fuse. A blown fuse and the window will not work at all. I would bet it if the window lift motor on its last leg.
The Z's (especially your early model "2003 350Z") are notorious for the window lift motor going bad. There is a DIY guide on the forum to get the door panels apart and gain access to the lift motor. It is a pain!
Hope that helps.
Old Jun 26, 2012 | 10:17 AM
cgkp0925's Avatar
cgkp0925
Hope that helps.
THIS.
It's been covered plenty of times. /thread.
Old Jun 26, 2012 | 02:40 PM
duro78's Avatar
duro78
Like mentioned above it will happen once in awhile then progressively get worse then not work at all.
Old Jun 26, 2012 | 05:30 PM
EyeOutThere
Sorry. I was in the wrong forum.
https://my350z.com/forum/maintenance...dow-motor.html
now, /thread.
Old Jun 27, 2012 | 11:09 AM
Z4ToddB's Avatar
Z4ToddB
Welcome to the newest member of the "Window Motor Club"! Been a member about 4-5 times over now between driver/pass. Latest one last week on the drivers side...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
