Clutch problems!!! Please help!
Old Jul 27, 2012 | 12:40 PM
daytona7135's Avatar
daytona7135
Default Clutch problems!!! Please help!
it started yesterday. I punched it a little and when i went to shift, i could not get into the next gear. I pumped the clutch a couple of times, then the car kicked like i jump started it. After this, the clutch peddle felt softer. I could get it in gear, but when i would take off it was really rough, and felt like the it was half way catching and half way not. It is still semi drive able, but i need to know what to replace. Is it the clutch, the flywheel, both?
Old Jul 27, 2012 | 03:25 PM
DavesZ#3's Avatar
DavesZ#3
what year? it could be the slave cylinder problem common on the 07s
Old Jul 27, 2012 | 04:10 PM
johnwigs's Avatar
johnwigs
stop driving it... no one even listens to sound advise anyways... so just do what ever your friend that works on honda's says to do!!!
Old Jul 27, 2012 | 09:06 PM
Mcutali's Avatar
Mcutali
sounds like slave cyclinder, and in the 07 its enclosed in the bellhousing unlike prior years with the de engine. what a pita good luck.
Old Jul 28, 2012 | 10:31 AM
daytona7135
its an 03
Old Aug 4, 2012 | 05:37 PM
binder's Avatar
binder
take it to a mechanic. Something isn't working properly between the slave cylinder or master cylinder.
Uriyo_
Sep 8, 2021 08:46 AM
