Codes p0303 and p0340
Old Nov 4, 2012 | 12:26 PM
Raginraj11's Avatar
Raginraj11
Default Codes p0303 and p0340
I was driving last night, car went into limp mode, SES, VDC off and SLIP light all came on and stayed on, car had trouble starting, pulled 2 codes, p0303 and p0340. Would p0340 (camshaft position sensor) be causing p0303 (cylinder 3 misfire)? If i replace the camshaft sensor, should that also fix the other code?
My car has had pretty bad oil consumption for the past 30k miles.
Old Nov 4, 2012 | 01:29 PM
JCITY's Avatar
JCITY
Yes.
Lately there has been a few posts regarding cam position sensors.
After one goes out,your dash will light up with "everything" looking
like its going out.Its quite posible that replacing the sensor will fix
the misfire code.Suggest you get a OEM sensor not aftermarket.
I don't see how the cam sensor would be related to your oil consumption
problem.
Old Nov 4, 2012 | 01:35 PM
Raginraj11's Avatar
Raginraj11
Yea i read a few other threads regarding this problem but wasnt sure if the camshaft sensor could also be causing cylinder 3 to misfire. I had the Drivers side one replaced last year with an oem sensor. Will be going oem again. Thanks!
Old Nov 4, 2012 | 03:49 PM
JCITY's Avatar
JCITY
Thumbs up
Some owners replace both if one goes out.If the code indicates bank #1
,passenger side,it sure is easier to to replace.
Hopefully that will solve your problem.
Old Nov 4, 2012 | 04:23 PM
Raginraj11's Avatar
Raginraj11
yea i shouldve just replaced both at that time. I hope so too.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
