Windshield Wiper fluid Reservoir removal
Old Nov 25, 2012 | 12:28 AM
mike_eee's Avatar
mike_eee
Default Windshield Wiper fluid Reservoir removal
Hello Folks,
this holiday before my big install of TDx2 and BBK kit, i thought i will change my headlights to modified ones and fix my non working wiper fluid.
After removing the nismo bumper, i saw that , the reservoir is half full, i was assuming that there will be crack and hence no fluid. Looks like the leak is the top half some where and still no fluid spray when i use the switch.
So i decided to remove it off , only one screw is holding it place and other looks like plastic grasp .I removed the top funnel off and the only 10mm screw, but for the love of god i cannot take the plastic grasp off...its held by that grasp on the right side, when looking from the front. I was wondering if any of you guys know, what is the proper way of removing the tank /reservoir?
Mike
Old Nov 25, 2012 | 01:08 AM
KingBaby's Avatar
KingBaby
Hardest Setting
There's another one going against the one you see! You kinda have to grab both at the same time to remove it if my memory is correct...
Good luck
Old Nov 25, 2012 | 01:54 AM
mike_eee's Avatar
mike_eee
i get ur point...but how do i free it??
Old Nov 25, 2012 | 02:25 PM
ocdz's Avatar
ocdz
ya its kind of a PITA! I took mine off last year. You have to reach up from the inside of the plastic towards the engine and there are two 10mm nuts in there holding it on. I used a ratcheting wrench and it still was quite inconvenient. Then it kinda slides up a little and then you can pull it out and slide the filler tube down through the fender.
edit: Check out this picture of the back side, it sounds like you missed a fastener if you only removed one 10mm nut.
Old Feb 4, 2013 | 02:31 AM
Zatara's Avatar
Zatara
What was wrong with the water pump? Why wouldn't it spray? My front wipers do but want to spray either. I switched the front water pump and still no spraying.
Old May 23, 2013 | 07:06 PM
IV_SD_350Z's Avatar
IV_SD_350Z
Bump.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
