Manual transmission issues
Old Dec 3, 2012 | 04:26 PM
stygian_z's Avatar
stygian_z
Default Manual transmission issues
So I replaced my clutch/flywheel etc. with the kit from import parts pro about 3500 miles ago. I did the install myself with some help from a couple friends of mine. Everything went smooth. Well ever since I replaced the clutch It's been a little hard to get it into each gear. It's not grinding at all. So I assumed it wasn't the syncros going bad. (I know i shouldnt assume) I also replaced the master cylinder and slave cylinder about 1000 miles ago with the same results. I've bled the clutch numerous times and adjusted the shifter and clutch pedal about 10 times. I never got around to putting the stainless line in because the screw on the fender it attaches is stripped out. (I used a box wrench 10mm instead of a flare nut wrench) so my question is where do I start to try and fix this problem? I'm out of ideas. I had a friend of mine tell me that I could have a faulty throwout bearing or pilot bushing. Oh and when I replaced the oem clutch it wasn't worn out. It wasn't even close to hitting the rivets yet. I just wanted to start at the drive train because i plan to spray nitrous if I can ever get this problem sorted out.
I drive an 06 6mt 350z enthusiast with 95k miles
Any help would be greatly appreciated
stygian_z's Avatar
stygian_z
Sorry for the long post in advance.
Old Dec 3, 2012 | 04:47 PM
Italianjoe1's Avatar
Italianjoe1
Stock fluid?
Old Dec 3, 2012 | 06:53 PM
stygian_z's Avatar
stygian_z
I put in pennzoil synthetic 75w90 then changed it to Valvoline synpower 75w90 about 1500 miles ago thinking that might be the issue.
Old Dec 3, 2012 | 06:54 PM
stygian_z's Avatar
stygian_z
The clutch fluid is dot 3 synthetic. Can't remember the manufacturer right this second.
Old Dec 3, 2012 | 06:55 PM
stygian_z's Avatar
stygian_z
http://www.performanceonline.com/ima...brakefluid.png
There's the clutch fluid I used.
Old Dec 3, 2012 | 09:48 PM
Resolute's Avatar
Resolute
Both of those are GL-5 gear oils. They are formulated for handling the higher pressures and shearing forces inherent to hypoid gears, such as your differential's ring and pinion. For your transmission, you want to use a GL-4 transmission oil. Pennzoil Synchromesh is a readily available option at most auto stores.
Will
Old Dec 3, 2012 | 10:51 PM
Italianjoe1
Yeah you are having synchro trouble from the fluid. Go back to oem or redline's fluid that is spec'd for these transmissions and see how it feels.
Old Dec 4, 2012 | 04:34 AM
stygian_z's Avatar
stygian_z
What weight redline fluid? Or can you send me a link?
Old Dec 4, 2012 | 05:05 AM
SlowNFurious's Avatar
SlowNFurious
Redline MT-85. Do you still have the bottle for the old fluid you put in? Many gear oils come in both GL-4 and GL-5. The pennzoil syn 75w-90 definitely comes in both GL-4 and GL-5, so I would not get your hopes up on this being the fix.
edit: I googled the Valv. synpower 75-90 you were using it it is in fact GL-5 only, so maybe it will be as easy as just changing out the fluid. Good luck!
Old Dec 4, 2012 | 05:43 AM
stygian_z's Avatar
stygian_z
Is it possible that the pilot bushing or throwout bearing are faulty? And/or that the clutch isn't fully disengaging and that's why the gears are rough?
stygian_z's Avatar
stygian_z
But I'm gonna put pennzoil synchromesh gl4 in it today and see if that changes anything. Thanks for the help guys.
Old Dec 4, 2012 | 06:46 AM
SlowNFurious
I don't see how the pilot bushing would be the cause, did you not change this out for the pilot bearing included with the kit? Did you replace the throwout bearing when you did your install?
Also, are you using an aftermarket short throw shifter?
Old Dec 4, 2012 | 08:53 AM
stygian_z's Avatar
stygian_z
Yes I replaced the oem one with the included roller pilot bushing. And yes I'm using the stock shifter. H
stygian_z's Avatar
stygian_z
And yes I replaced the throwout bearing with the included one.
Old Dec 4, 2012 | 11:36 AM
VQdriver's Avatar
VQdriver
I've always wondered about Pennzoil Synchromesh fluid. I must have a million posts spreading the word about Redline MT-85 and Nissan MTF as good fluids to use. Let us know how that works for you! Also, did you do your clutch job with a set of jackstands or on a lift? That must have been fun!
Old Dec 4, 2012 | 01:01 PM
stygian_z's Avatar
stygian_z
I actually am good friends with the manager of a local oil change place that I used to work at. So I used one of their bays for about 5 hours lol the transmission only weighs about 90-100 lbs which was very surprising. It's just awkward weight. If I end up removing the transmission again then ill do it on jack stands and use a little transmission jack.
Old Dec 4, 2012 | 05:07 PM
stygian_z's Avatar
stygian_z
So I replaced the fluid with synchromesh today and Its 1000 times better so better. I'm hoping it'll get a little bit smoother after the fluid gets hot a couple times and coats everything again. I guess I need to drive another 350z or g35 around here and see how there's feels before doing anything else.
Old Dec 4, 2012 | 05:46 PM
faiz23's Avatar
faiz23
FEZZZZZZ
You do realize that when you drain and fill you only end up getting like 3.5 quarts and I think the tranny holds like 9 quarts or more. You will need to do 3 fluid swaps (drain and fill) to end up with 93% new fluid. It is typically when you steer away from OEM fluid that you run into issues with the gear box. I would drive it for a 3 days and then drain and fill it again with OEM fluid and do it a third and final time. That is a cheap fix and should take care of most of your issues.
Old Dec 4, 2012 | 05:58 PM
Italianjoe1
the manual trans holds 9 quarts? You sure about that???
