Look at my Align specs whats wrong
Old Jan 31, 2013 | 04:33 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Default Look at my Align specs whats wrong
Stance Coils lowered about finger flush
I dont think its perfect all the way around but i doubt that has anything to do with it.
SPC Rear camber arms
Grand touring wheels
18 F 19 R no spacers
275/30/19 Rear Nitto NT5
265/35/18 Front same tire
The place I went now afterwards I dont think He knew how to deal with a lowered Z with camber so let me know
Its a DD no track or drag just spirit driving
Thanks a lot for the help I dont have enough info or knowledge per say to give him the info he needs
Thanks for all the help
Old Jan 31, 2013 | 04:39 PM
nismonian's Avatar
nismonian
no expert but your rear camber is way off.. theres almost a degree difference.
i'll let the more knowledgeable chime in though.
Old Jan 31, 2013 | 04:42 PM
2004Black350z
Exhaust Whore
I know but idk what to tell him to fix it. Front tires are already so chopped sounds like a tractor trailer slowing down.
Old Jan 31, 2013 | 05:34 PM
steidz's Avatar
steidz
If you want to fix the front camber, less for better tire wear, youll need adjustable upper control arms.
The rear probably needs spc toe bolts( or other brand). As you pull the camber in (less camber) you add (toe in) to that tire. He has the rear toe matched. Its just a guess but he might be at the limit of the toe adjustment and had to leave the higher neg camber setting on the right side. The SPC bolts will give some more adjustment for the toe so the rear camber can be matched better.
Old Jan 31, 2013 | 05:37 PM
bmyles's Avatar
bmyles
Your toe is way way off. That is what is wearing down your tires. Specs for both front and rear toe are very similar...in the ball park of 0.03 - 0.09. Can't adjust front camber unless you get adjustable arms, but rear camber can be adjusted to an extent. With your being lower, I'd say an even -2* on each side would be much better than the uneven setup you have now. Sounds like you might need to invest in adjustable arms or bolts, though.
2004Black350z
Exhaust Whore
Good call found spc bolts at z1 for 28$. Sold lol. What's the proper technique when adjusting camber as in max out x for y or wgat
Old Jan 31, 2013 | 05:39 PM
2004Black350z
Exhaust Whore
Ok so run -2 camber sounds good thanks
Old Jan 31, 2013 | 05:41 PM
bmyles's Avatar
bmyles
I'm not an expert on the amount of camber you should run, however, I know factory spec is around -1.5 to -1.7 or so. Being lower, nothing wrong with -2, but it matters what you're trying to do. I think I still have my Firestone sheet. I'll take a look at it when I get home.
Old Jan 31, 2013 | 05:47 PM
2004Black350z
Exhaust Whore
Do I need to perfect my ride height? As in make it Perfect all the way around which honestly I have no idea how I'm gonna do that
Old Jan 31, 2013 | 05:56 PM
steidz's Avatar
steidz
Small changes that your talking about won't matter, but you do want your ride height set before you get aligned. If your daily driving only I would try to get back close to spec settings. That will give you the best tire wear.
Old Jan 31, 2013 | 06:26 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
If you are just trying to level out your car without making any major height adjustments, use the collars under the spring. IMO, do this with a full tank of gas so when your tank gets low you gain rake...opposed to adjusting your height on an empty tank and then you fill up your car, the rear will sit lower than the front.
Old Feb 1, 2013 | 05:57 PM
2004Black350z
Exhaust Whore
Full tank of gas check. What's the easiest way to get the ride height in all corners near perfect?
Also any align spec gurus chime in with numbers?
Old Feb 1, 2013 | 06:20 PM
AdvanZ33's Avatar
AdvanZ33
I measure wheel/fender gap and raise/lower my collars the same measurement per corner.
Old Feb 1, 2013 | 06:22 PM
2004Black350z
Exhaust Whore
What are you lowered on? And good info that makes sense lol
Old Feb 1, 2013 | 06:25 PM
AdvanZ33's Avatar
AdvanZ33
http://performance-suspension.eibach...r/pro-street-s
I don't care about things like "dampening," just want the adjustable ride height.
Old Feb 1, 2013 | 06:28 PM
2004Black350z
Exhaust Whore
Nice. This is my first lowered Z lol. 3rd Z though. Its a headache bc of the tire wear im getting the alignment idk how to get ok and the front tires are already ruined bc the choppyness
Old Feb 1, 2013 | 06:38 PM
AdvanZ33's Avatar
AdvanZ33
When I had my Tein S-Techs (less than 1" drop) my alignment stayed in spec without aftermarket suspension components.
I see you have 275/30/19 in the rear which is around 1/2" shorter than stock tires meaning you can't raise the car back to stock height without having massive wheel gap. Also, if you have VDC you might see your SLIP light illuminate under spirited driving because your front and rear tires are almost the same height.
Old Feb 2, 2013 | 08:32 AM
0jiggy0's Avatar
0jiggy0
Is this after he tryed to align it?
1 you need more adjustment to correct at least the camber. Your caster is also way off. but I'm sure you'll need expensive pieces to correct that.
2 I dont think the tech knows what hes doing. No matter what your toe should not be that far off.
Old Feb 2, 2013 | 08:53 AM
bmyles's Avatar
bmyles
Ok, I have my Firestone alignment sheet here. I'm stock height, however, toe should be similar. I am at 0.09 left, 0.05 right for toe on the front and 0.07 left, 0.10 right for toe in the rear. Yours is insanely higher. As for camber, I'm at -1.9 left, -1.8 right in the rear. That's why I said -2 should work fine for you if you're not slammed.
Old Feb 2, 2013 | 09:35 AM
2004Black350z
Exhaust Whore
Jig I kidney get the same feeling. I have an alignment machine in my shop however I'm to low. But if someone can tell me what they should be and the procedure well try it here. Also the caster isn't correct at all.
Bmyles yes my car is pretty low. So we're not comparing apples to apples
