HELP WITH THESE 2 CODES! cant figure it out!
Old Jul 15, 2013 | 08:47 AM
tw8715's Avatar
tw8715
Default HELP WITH THESE 2 CODES! cant figure it out!
i have replaced my front 2 o2 sensors that are before the cats. still get this code. replaced maf. cleaned throttle body (BTW this smoothed out my idle a lot!) changed my plugs, took my fuel injectors to DR Injectors and had them tested and cleaned. dont know what else could be left??
car is STOCK! except MD plenum spacer.
Old Jul 15, 2013 | 12:59 PM
tw8715's Avatar
tw8715
Bump help
Old Jul 15, 2013 | 01:42 PM
seymore4's Avatar
seymore4
Professional
Are you sure there aren't any exhaust leaks? Failing cats? (that would usually be a 420 or 430 tho) I would recommend getting the AFR's checked. Could be that its actually running wierd and needs a tune.
Old Jul 15, 2013 | 04:22 PM
tw8715's Avatar
tw8715
How would I check that? What would cause this to mess up?
tw8715's Avatar
tw8715
It's stock so I don't understand why tune would be needed
Old Jul 15, 2013 | 05:54 PM
seymore4's Avatar
seymore4
Professional
you have a plenum spacer.. that usually won't cause any issues but idk. There's no way to diagnose this over the internet.. it could be anything, even faulty wiring causing it to short out. but I would check the air/fuel ratio (either on a dyno or by datalogging) and see if its actually running rich/lean as a starting point
Old Jul 15, 2013 | 07:20 PM
jhc's Avatar
jhc
General & Tech Moderator
Try this:
Connect a vacuum guage to your intake manifold and compare to spec.
The primary sensors send fuel/air to the ecm,, the secondary sensors monitor the cats.
If you have a spacer, and low vacuum, reinstall and/or use a sealer.
Good luck!
Old Jul 18, 2013 | 01:27 PM
tw8715's Avatar
tw8715
bump! any other ideas?
Old Jul 20, 2013 | 01:31 PM
dilat3d's Avatar
dilat3d
jhc is right, you may have a vacuum leak ... check all vacuum lines ... you can also smoke the intake manifold which would cause said smoke to sneak out of any cracks/spaces on the intake path
Old Jul 21, 2013 | 02:09 PM
tw8715's Avatar
tw8715
Yea smoked it out. No vaccumne leaks. Could it be the rear o2 sensors?
lapham3
Oct 7, 2022 03:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
