Help. Burning/Melting Smell
Old Jul 25, 2013 | 05:29 AM
darkhonda2k2's Avatar
darkhonda2k2
Default Help. Burning/Melting Smell - Updated. Brake fix ideas?
Updated in post #8.
2003 350z, 6MT, 101k
Last night my GF's Z started having a very troubling burning/melting plastic smell after a short ~15min drive.. oil pressure and temp gauge read normal.
when we got it home i took a look but found nothing obvious... then hit up the search function here and went on a hunt for a plastic bag on the exhaust but found nothing.
We did notice what seems to be a very hot spot around the passenger strut shown in red.. this entire area was at least 20* hotter (by touch) than its mirror
tonight i am going to take a look at the brakes to see if it may have seized but i dont know why that would smell like plastic burning.
Any ideas?
Old Jul 25, 2013 | 05:44 AM
travlee's Avatar
travlee
Master
maybe a wire got pinched and it grounding out, melting the casing?
Old Jul 25, 2013 | 05:46 AM
darkhonda2k2
Wiring did cross my mind, and the factory harness is right there, but the wireloom itself did not feel hot. I will be sure to investigate that when i look it over tonight.
Old Jul 25, 2013 | 09:43 AM
Touge Z's Avatar
Touge Z
my car does the same thing and it does seem to be coming from the passenger side, but there seems to be some plastic bag that was burnt onto the passenger side exhaust pipe. I'm gonna burn the rest off and see if that's the cause.
Old Jul 25, 2013 | 09:56 AM
travlee's Avatar
travlee
Master
i had a big trash bag hit at my X pipe and then melt all the way to the muffler, and it smelled so bad, but not from under the hood. i guess if it hit the cat or something dropped on the header then it would
Old Jul 25, 2013 | 10:33 AM
darkhonda2k2
haha those bags seem to be a pretty common problem for your Z's. I literally found 10+ posts where that was the issue when i searched for "burning smell"
I did a quick look under last night but couldn't lift it up as I had lent my jack to a friend yesterday.
Ill look again tonight for that but in the meantime.. Any one have any other ideas?
Old Jul 26, 2013 | 11:11 AM
darkhonda2k2
so last night i put it up on stands, searching for that plastic bag... i saw no bags, but i did find a small mark of something that may have been a bag, so i took a wire brush to it.
i then ran the car for about 20-25min.. no smell, no hot strut tower bar.. so i went on to take apart the passenger brake to reset the caliper in case it had gotten stuck. the back pad was pretty blackened when i cleaned it so i think that may have been the issue. i will post back with final checks later tonight.
Old Jul 26, 2013 | 05:11 PM
darkhonda2k2
Well that was disappointing... felt the fender/strut area after just a 2.5 mile drive and it was getting pretty hot again
came home a sprayed a little water at each front caliper and the passenger sizzled instantly.. 100% that brake is binding.
any one have any rebuild/clean-up ideas before i have to buy new calipers?
AbrasiveRaysive
Sep 20, 2021 02:29 PM
3vilbunny
Jul 18, 2017 05:10 PM
_koubie_
Sep 20, 2015 06:34 PM
PureR3d
Sep 10, 2015 06:23 PM
