350Z Oil Change
Originally posted by zuddenly
where do you get those safety stand adapters??? anyone have em?
Not yet... I use ramps.
cool thanks... i've been sticking thick thick thick folded cardboard to cushion my jackstands and the jackpoints.... should've searched for these a long time ago... fortunately, the cardboard works and my jackpoints arent bent...
Originally posted by pulpz2
Anybody just leave the under engine bay cover off?
Nissan forgot to attach 3 of the 6 screws that hold it on my last oil change... I reamed them for that - just plain laziness there.
On a side note, anyone know if adding this will allow the plastic cover to fit still??
Oil pan spacer: http://www.performancenissanparts.co...roducts_id=741
Just curious... thanks!
dunno about the oil pan spacer.
After I took the cover off and changed the oil for my first time I realized it would be best to put the cover back on. As you say, aerodynamics plus I'm sure it provides some degree of protection.
Btw, used Mobile 1 Synthetic 5W-30.
I've tried many different kinds of filter wrenches, but the best one for everyday use is the one that looks like a huge socket. However, if the filter is stuck, this one works best:
It's Sears item #00946955000 Mfr. model #46955
It crushes the snot out of the end of the filter, but it has removed every stuck filter I've tried it on. Plus, it's only $7.
I could never get the strap kind to not slip, especially if there's stuff in the way like the exhaust manifold.
Asterix
Asterix
bcoffee20
Nov 19, 2015 06:39 PM
