Air Bag - Yellow Wires popped out of socket!
Old Aug 11, 2013 | 08:42 AM
350z_uk's Avatar
350z_uk
Default Air Bag - Yellow Wires popped out of socket!
Hi all,
I took my seats out to give them a really good clean, I unplugged the usual. The Electrics for the seat movement, the sensor for the seatbelt catch and lastly the front yellow plug for the airbag.. BUT
When I pulled the yellow plugs apart the wires and connectors came out of the yellow plastic bit !
I can easily put them back in and fasten the catch but the problem is they are IDENTICAL.. I'm not sure which yellow wire goes to which side of the plug.
Can any airbag experts please help?
1) Does it matter which identical yellow wire goes into which side of plug.
2) In airbags (not just 350z) does it usually matter about the polarity ?
I have everything ready to go back together but cant as I don't want to trigger my airbag!!
Thank you
Old Aug 11, 2013 | 11:41 AM
350z_uk's Avatar
350z_uk
took a big risk....
Plugged the wires in one way around and tested... it worked.
Then took the yellow wires out again and swapped them over. Plugged it back in and again it worked. So I would guess that it doesn't matter which way round the wires go.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
