Radiator Fan Operation advice.
Old Sep 6, 2013 | 09:10 AM
modd1uk's Avatar
modd1uk
Default Radiator Fan Operation advice.
Hi guys, after a little advice. It may differ slightly as i'm in the UK so my car is RHD but which fan should be running ? I have two fans obviously and when the car has been idling for a bit then my drivers side fan kicks in to cool stuff down.
The temp never exceeds just under 50% on the needle. When i turn the AC on the same drivers side fan spins, but i'm yet to see the passenger side fan spin at all is this normal ? Is the second fan just supposed to kick in when temps get really high ?
06 Revup Z
Old Sep 6, 2013 | 10:30 AM
modd1uk's Avatar
modd1uk
Guys on the UK forum think both fans should kick in when the AC is on, yet a lad i know with a Z second fan doesn't kick in with aircon, but did kick in when he was having coolant change and his car got hot enough ?
Just need to know if both fans should kick in with air con or if the secondary fan is only there for when temps get really hot.
Chris350z03
Oct 8, 2023 07:19 PM
SharX59
Sep 30, 2015 10:54 AM
mjgfish
Sep 22, 2015 05:55 AM
EnjukuRacing
Sep 18, 2015 07:57 AM
