2003 350z Clutch disengaged noise.
Old Sep 22, 2013 | 11:55 AM
Jakoby's Avatar
Jakoby
Default 2003 350z Clutch disengaged noise.
Ok, well i noticed that when im in sitting in nuetral and let the clutch out there is this chatter you can hear, and when you put the clutch in it goes away. It can get annoying and im not really sure what the problem is. I did a little research on what it could be and i found that it might be an input shaft bearing. but i am not certain, if anyone knows a way to find out to be sure of what it is please let me know. thank you
Old Sep 22, 2013 | 12:21 PM
terrasmak's Avatar
Could be, but it is usually the dual mass flywheel making a little noise. Very common on these cars.
Old Sep 22, 2013 | 12:42 PM
travlee's Avatar
travlee
Master
alot of the cars sound like a cement mixer when in neutral idiling....
Old Sep 22, 2013 | 01:06 PM
oldschool350z's Avatar
oldschool350z
Very common . Nothing to worry about it's just annoying.
Old Sep 22, 2013 | 01:11 PM
travlee's Avatar
travlee
Master
and it will only get worse if you put a light weight flywheel in
Siqcology
Sep 18, 2019 01:45 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
foxsmp26
Sep 25, 2015 09:48 AM
RWDBajan
Sep 8, 2015 06:25 AM
