Shifter moving under accel/decel
Old Oct 7, 2013 | 11:34 AM
slowstang06's Avatar
slowstang06
Default Shifter moving under accel/decel
hey all, my 08 Z has about 84k on it, and I noticed on the interstate (especially in 5th and 6th gear) the shifter will move back (towards me) when I am on the gas and if I let off the gas it will slightly move forward. It vibrates a little at idle, but nothing too crazy I don't think. I'm just wondering if this is normal for a Z (I just bought it and I'm coming from having a built mustang where just about everything vibrated a little bit lol) or if it might be a motor/transmission mount? Should I be concerned?
VIDEOS:
Idle
Moving forward and back
thanks!
Old Oct 7, 2013 | 11:36 AM
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
If you could post a video, that would help out. Mine vibrates as well, nothing out of the ordinary.
Old Oct 7, 2013 | 11:47 AM
slowstang06
Thanks! I will get a video of it while driving once I get off work -- provided the interstate isn't a parking lot itself.
Old Oct 7, 2013 | 12:21 PM
Jennifer 2's Avatar
Jennifer 2
Slowstang, in front wheel drive cars the shift lever mechanism is bolted solidly to the car body and operates the trans through cables. In front engine rear wheel drive (as God intended) cars, the shifter mechanism and shift lever are bolted solidly to the trans. The engine/trans are bolted together and ride on rubber bushings. As you accelerate/decelerate the whole engine/trans/shifter unit will move around bit. Totally normal. If one of the trans or engine mounts is broken then you would see an exaggerated movement in the shifter, but you would also feel the overall slop in the whole drive train.
Old Oct 7, 2013 | 01:56 PM
350ZZJoe's Avatar
350ZZJoe
My car does the exact same thing. If you are barely on the throttle on highway speeds and let off you can feel the shifter sort of 'pop' for lack of a better word.
I've always noticed it but just chalked it up to the way the car is made like Jennifer just explained above.
Old Oct 7, 2013 | 02:00 PM
slowstang06
Thanks Jennifer 2! I don't think it was that bad that I feel the whole drivetrain. But as promised here are the videos, first is idling the second while driving (accel and then off gas)
View My Video
View My Video
apex locator
Oct 6, 2015 05:58 PM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
