Need help with Turbonetics turbo kit
I have a Turbonetics kit with the Turbonetics T60-1 turbo on my 2003 touring 350z. I has started to blow, white smoke really bad, thought it was a bad turbo, removed the turbo and discovered a bunch of oil pooled in the coupler. Has anyone had this issue before? Can I replace the turbonetics with a precision turbo, if so which one should I go with?
white smoke means coolant in combustion - ie cracked block and/or blown head, oil in your turbo coupler means blown seal.
time to pull/rebuild the block and have your turbo rebuilt/replaced…
how did this happen?
