350z stalling when driving and put in neutral. really weird please help
Old Nov 4, 2013 | 04:37 PM
cchmelir's Avatar
cchmelir
Default 350z stalling when driving and put in neutral. really weird please help
hey guys i looked around and cant find anything exactly like this. so i replaced my spark plugs the other day and after everything ran fine i even drove about an hour and a half each way to visit my family and everything went fine but 2 days later my car started acting weird. ill start it up and start driving everything seems fine until i put it in neutral to coast to a red light and the engine will stall out on me. i start it back up and seems fine. but after it happens when i hit the gas and go into first it sputters for a second like it is going to stall.
i was thinking it could be a vacuum leak but i didnt see anything. also i have a exhaust leak that i just ordered a new part to fix it but i dont think that it would cause this. the same thing happened about 4 months ago but it went away when i turned the car on the next day it was fine so didnt think much of it. maybe im just missing something really small but i cant seem to find out whats wrong with it. its a 2004 touring model with 116,000 miles i have a couple of mods like a plemum spacer and a cold air intake but thats it. i dont have the stock intake it put back on and try it. also i had replaced the maf and both cam sensors a couple months ago so dont think thats it. im stumped so any help would be awesome thanks so much guys!
Old Nov 4, 2013 | 05:17 PM
KornerCarver's Avatar
KornerCarver
Why do you put the car in neutral to coast to a red light? Try leaving it in gear and see what happens.
Old Nov 4, 2013 | 05:58 PM
cchmelir's Avatar
cchmelir
that is what im doing now to prevent it from stalling but it still stalls sometimes. and its not running right
Old Nov 4, 2013 | 06:03 PM
SQuaLZ's Avatar
SQuaLZ
Almost positive it's the intake. Common problem on the Z. I am not sure how to fix it though but I am sure if you look on here you will find plenty of info on it.
Old Nov 4, 2013 | 06:33 PM
Z_on_TE37's's Avatar
Z_on_TE37's
It's probably getting the wrong amount of air. Do an ecu reset and the throttle position and idle air learning procedure
Old Nov 5, 2013 | 03:38 AM
mcarther101's Avatar
mcarther101
Crank pos sensor possibly too. There's a service bulletin about the Crank pos sensor causing this on some Z's.
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
_koubie_
Sep 20, 2015 06:34 PM
Darkspy
Sep 7, 2015 09:09 PM
