****Cams positioning Help****
Old Nov 5, 2013 | 05:04 AM
Lab-mike's Avatar
Lab-mike
Default ****Cams positioning Help****
Can you tell me is there any way for the cams timing to be off if all the markers are lined up with the cams shaft chains and all markers line up on the timing chain?
Old Nov 6, 2013 | 03:52 AM
Lab-mike's Avatar
Lab-mike
No one has a answer for this?????????????
Old Nov 6, 2013 | 07:07 AM
Calinismo350z's Avatar
Calinismo350z
where did you got the marks from.? 2 yellow should be on top red one on bottom?
Old Nov 6, 2013 | 01:41 PM
mcarther101's Avatar
mcarther101
http://www.nicoclub.com/FSM/350Z/coupe/2003/em.pdf
EM-70 has service procedure... I don't think so unless the chain is worn maybe?
If everything is installed correctly, shouldn't be an issue. If installed incorrectly, you probably would have bent a valve or something from valve-piston contact I'm guessing.
Dr.Paulyy
Jul 29, 2019 07:45 AM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
