350z Drive side Windows issue
Old Dec 12, 2013 | 09:27 AM
ruban's Avatar
ruban
Default 350z Drive side Windows issue
Hello everyone,
I need your help again. This time its the Window.
I can replace the motor and it will be all good but as of now money is tight and so I need your help and a temp fix.
My Window on the drive side rolled down and it won't come back up.
I open up the door and thought cleaning up everything around the motor will fix the issue but no luck.
I tried manually pulling the window up but I guess it does not work that way. The claps on the both side track are holding the glass too strong.
So my question, is there a way for me to pull the window up manually without replacing the motor right now?
I just need the window closed by any means. Security issue and its too cold here to drive with windows rolled down.
Please share your tips and experience.
I have only one car and the place where i work, i cannot park it with my window open. Need to fix this asap ): Please help.
Following are some pictures of where i am right now.
Old Dec 14, 2013 | 12:51 PM
ruban's Avatar
ruban
No help?.
Old Dec 17, 2013 | 03:35 PM
samsniss350z's Avatar
samsniss350z
Ruban, the only 'quick fix' I can think of would be to go through the relearn procedure for the motor, but chances are your motor is shot and the only thing you can do if money is tight is to try and fix it. Its not difficult and at the top of this page are excellent instructions on how to go about it. Hope this helps, good luck.
Siqcology
Sep 18, 2019 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
issyz
Sep 12, 2015 04:18 PM
AP350z223
Sep 8, 2015 04:38 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
