2007 hr won't rev over 6000 rpms
Old Dec 20, 2013 | 03:32 PM
Daytondakid13's Avatar
Daytondakid13
Default 2007 hr won't rev over 6000 rpms
The car turns on just fine but when you drive it or have it in neutral the car won't rev over 6000 rpms.
It hits 6000 rpms and then acts like its hitting the limiter some what.
Pulled the codes off my cobb ac
Codes:
Ecu
P1084
Exh_Tim_Sen/Cir-b2
P0345
Camshaft Position Sensor A Circuit (Bank 2)
So everything is happening in bank to and i feel like the camshaft sensor is bad which is causing the exhaust timing sensor to be bad or be off. If anyone with the same issues or can help me solve this i would greatly appreciate it, I'm trying to get the problem solved before going back to school for winter break.
Old Dec 20, 2013 | 03:40 PM
Italianjoe1's Avatar
Italianjoe1
Replace that cam sensor and see if it improves. They are a common failure item on these engines.
Old Jan 26, 2014 | 06:34 PM
Daytondakid13
bump
Old Jan 27, 2014 | 08:25 PM
Italianjoe1
Did you change the cam sensor?
Alexreyes
Sep 30, 2015 11:30 PM
