Window Problems Passenger Side
Old Jul 6, 2014 | 10:31 PM
sfwschamps2010's Avatar
sfwschamps2010
Default Window Problems Passenger Side
I have a 2007 Z, and I have been having trouble with the window on my passenger side. I know I probably should not have been banging my door panel when it was going out, but it was a quick fix. Originally, I though it was the motor, so I went ahead and looked at the tutorial and replaced it because that is what I thought would fix it. Turns out that it isn't the problem, and that the motor is good.
Anybody had any trouble with wiring/fuses with this car??? I am all out of ideas on what to do next.
The reason I dont think it is the fuses is because the passenger window will not work for the switches on both sides.
Thoughts?
Old Jul 7, 2014 | 02:27 PM
guitman32's Avatar
guitman32
was it a reman motor? i ask only bc ive gotten "new" reman motors that were doa...it even looked good just testing the motor on one, but when installed in the reg with the glass on it wouldn't work.
have you verified the window motor is getting power or not? how do you know the motor is good?
Old Jul 7, 2014 | 08:40 PM
sfwschamps2010
I finally got it to work, thank you for the insight. I just took it apart and put it back together again and wallah. Must have been a look connection.
Uriyo_
Sep 8, 2021 08:46 AM
