Help!
Old Sep 6, 2014 | 02:21 PM
Mgtexture123's Avatar
Mgtexture123
Default Help!
My left fan won't turn of after the car is turned off!! It drain my batter last time help me
Old Sep 7, 2014 | 10:39 AM
laurentj23's Avatar
laurentj23
1.identify which fan? Does the ac work or the car overheat?
2. Check the fuse. Refer to your fsm. If you're not sure, ask your friend, wife, mechanic.
3.ifthe fuse is ok, than check the relay if it has one. Check on youtube on how to test your relay.
4.check your temp sensor if it's the radiator fan
5.jump start the fan.
6.replaced the fan
