New 350Z Owner need help please
Old Sep 24, 2014 | 05:27 PM
El Sancho's Avatar
El Sancho
Default New 350Z Owner need help please
I need help. The OBD showed a crankshaf pos code I swapped that out. Then I tryed to start it and it tries to crank up but dies before it stabilizes. I checked the OBD and the code it gave me was P000. I disconnected the crankshaft pos and it will run after cranking for a while. It doesn't stall and runs fine with the exception of a little shuddering. I connected the crankshaft pos while it's running and nothing changes. Then I turn it off and if I crank it back up right away it will start up fine, but if I wait too long it goes back to cranking but not stabilizing enough to stay running. Its weird to me I've done everything I can think of short of bringing it to the dealership. I trouble shot it according to the factory manual. I think the ecu is bad but I don't know how to text that. Someone help me please before I set this car on fire, lol!
Old Sep 24, 2014 | 05:41 PM
tommy smith's Avatar
tommy smith
Default I can't help you but
Originally Posted by El Sancho
I bought a 350Z from a friend at first the OBD showed a crankshaf pos code I swapped that out. Then I tryed to start it and it tries to crank up but dies before it stabilizes. I checked the OBD and the code it gave me was P000. I disconnected the crankshaft pos and it will run after cranking for a while. It doesn't turn off. I connected the crankshaft pos while it's running. Then I turn it off and if I crank it back up right away it will start but if I wait too long it goes bact to cranking but not running. Its weird to me I've done everything I can think of short of bringing it to the dealership. I trouble shot it according to the factory manual. I think the ecu is bad but I don't know how to text that. Someone help me please before I set this car on fire, lol!
You should change the first sentence a bit. " I bought a 350z from a friend "
Old Sep 27, 2014 | 04:48 AM
El Sancho's Avatar
El Sancho
Is there a special procedure when swapping a new crankshaft position sensor. Was I supposed to reflash the ECU?
Workshop12
Mar 23, 2020 01:45 PM
chief3630
Feb 29, 2016 02:54 PM
SonnyWu
Nov 24, 2015 08:19 PM
davidm350
Oct 31, 2015 02:28 PM
416blueZ
Sep 25, 2015 10:00 AM
