Just replaced clutch kit EXedy OEM
Old Apr 3, 2015 | 06:33 PM
theshrink1's Avatar
theshrink1
Default Just replaced clutch kit EXedy OEM
So I had an Exedy OEM clutch kit installed today. I got a chance to hand around and watch them do the install. The mechanic pointed out some wear on the shaft that enters the flywheel/crank casing. How normal is that and is it a cause for concern. They grinded it down a bit but still felt a little ridge. See pic.
Also the flywheel had some play but they said it was a judgment call, could be fine but it was close. I elected to have them complete the install. Overall, I have not noticed any problems today.
Also, I noticed that the clutch engages quicker and lower than usual, is that normal since it is a new clutch or do I need to adjust it? Should I replace tranny fluid ? The machanic seem to take the approach, if its not broke don't mess with it. I told them to do the rear main seal but they said there is no leak, better not to miss with it because then if you take the oil pan off, you may have to deal with the oil pan gaskets or something...
THoughts?
Last edited by theshrink1; Apr 4, 2015 at 09:54 AM. Reason: adding more information
Dr.Paulyy
Jul 29, 2019 07:45 AM
Ace2347
Sep 22, 2015 03:12 AM
