clutch bleed problems, please help
Old Apr 4, 2015 | 04:38 PM
mkisor's Avatar
mkisor
Default clutch bleed problems, please help
ok, I have an 05 z, i went to bleed the clutch and my stupid self left the rest cap off. well first Crack of the bleeder and closed it, the pedal lost all pressure and has to be pulled back by hand, I put the cap back on and have tried pumping and holding it and opening the bleeder...nothing. please help, how do I get pressure back
Old Apr 4, 2015 | 06:16 PM
travlee's Avatar
travlee
Master
you need to pump the ish out of the pedal, it will build pressure. it is easier with 2 people..... bribe a buddy with beer to help you
Old Apr 4, 2015 | 08:27 PM
bealljk's Avatar
bealljk
+1 to having two people...
Old Apr 4, 2015 | 11:46 PM
mkisor's Avatar
mkisor
I've pressed the ish out of the pedal, opening the bleeder each time, no fluid has came out, also having to pull the pedal back each time because there is no pressure. I have 4 mechanics here were all at a loss, we even put a vacuum on the bleeder and still can't get fluid to pass.
Old Apr 7, 2015 | 09:22 AM
rustyschopshop's Avatar
rustyschopshop
Maybe you have a colapsed clutch hose, you may concider upgrading to braided stainless.
Uriyo_
Sep 8, 2021 08:46 AM
