Fan assembly issues...
Old Jun 7, 2015 | 08:20 AM
AGreenZ's Avatar
AGreenZ
Default Fan assembly issues...
Hey guys so I recently just had a new fan assembly and radiator put in my car after a minor front end collision. Everything has worked fine but today I was stuck in traffic with the AC on and noticed my them gauge was going up... I turned the AC off and turned the heat on so draw the heat from the engine bay and it cooled off quickly. I got to work and checked the fuses none of them are blown but I did notice when I turned the AC on only one fan was working... What could be causing this or has anyone else had this happen to them?
Old Jun 7, 2015 | 10:15 AM
bealljk's Avatar
bealljk
The fans arent functioning correctly...
the fans are two stage - stage one both fans will kick on 'low mode' - typically around engine coolant temp of 205* F and will turn off around 195* F. The fans have the ability to go into a 'high mode' around 210* F.
If only one fan is turning on than there is an issue with either the relay, wiring or the fan itself.
I also speculate that you have air in the radiator and it needs to be re-bleed. The VQ's (as you know or soon to find out) are difficult to bleed.
Old Jun 7, 2015 | 11:30 AM
AGreenZ's Avatar
AGreenZ
So air in the radiator would stop the fan from working or cause it to over heat.?
Old Jun 7, 2015 | 06:28 PM
bealljk's Avatar
bealljk
no...you have two independent problems...
I would worry about the air in the cooling system first...it's a cheaper fix and is more important than a single fan not functioning...
Who did the fan/radiator install work on your car? Can you go back to have it fixed?
EnjukuRacing
Sep 30, 2015 06:55 AM
mjgfish
Sep 22, 2015 05:55 AM
