Urgent: Need Help. No Hot Air from Heater while idle.
so leaving my work in a snap freeze today, i realized that my car was blowing cold air, even when the heater was cranked all the way up. i was completely out of coolant. i ran to the gas station and grabbed some. accidentally filled up my overflow tank ALL THE WAY, like an idiot. My dad came and helped me, cause he was awake nearby, he bought me another bottle of coolant. we filled up my radiator and let it idle for awhile. the window defrosted, but my car still wasn't blowing any hot air. we decided to drive the car to make sure that i wouldn't overheat. the car did fine, we got it home. it finally blew luke warm on the way home. but nothing as hot as usual. when i looked at it later before work, it still wouldn't blow any hot air. we bled the system, and there was alot of air in the system, but that didn't seem tot fix the issue.
now while the car is idling, the hose that takes the coolant into the block is cool and the hose that takes the coolant out is hot. am i clogged somewhere? is my blend door(i believe its called) disconnected from the switch? is my heater core bad? should i get a full system flush or should i try bleeding it again? any help and ideas would be great.
basic troubleshooting, which you kinda did, should lead you to the thermostat. just my 2 cents, you might want to keep up with basic maintenance on your car better, coolant doesnt just disappear overnight (unless you have a bad leak, and then you would see it on the ground)
So, I can't tell from your posts but did the engine get to a normal temp? If it didn't its most likely the thermostat. If the engine did get to temp it's more likely an air bubble problem. If you think the radiator cap is damaged, do a pressure test. I am guessing you can rent a pressure tester.
Either way the car is hard to bleed if you don't follow nissan instructions. It's apparently easier if you have a vacuum bleed system, never tried this way, or a , I have had good luck on other cars with this system, along with following Nissan's instructions.
Either way the car is hard to bleed if you don't follow nissan instructions. It's apparently easier if you have a vacuum bleed system, never tried this way, or a funnel that fits on the radiator cap, I have had good luck on other cars with this system, along with following Nissan's instructions.
the engine gets to normal temp. where would i get a pressure tester? like o'reillys or auto zone or a specialty shop? what are Nissan's procedures for bleeding the system? cause someone on a similar thread said to have someone rev to 2 or 3k and hold it for a few seconds while i slowly open the bleeder valve.
so jack that side of the car up and then follow those steps? run it tile it warms up, rev it, then open that bleeder valve? and just repeat?
There are two kinds of threads you'll find on this topic. A few describing the proper technique and tools required, and then a whole crapload of threads describing failure due to not reading the other threads, or the FSM, for that matter. Guess which type of thread this is.
I thought I'd chime in with my experience on this as my heater was also blowing cold air at idle. I followed the FSM procedure to remove air from the system. The FSM does not mention anything about having the car parked on an incline to do this. I cheated a little bit and added my own step to the FSM to make things easier. Basically, once my radiator and overfill tank were filled to the proper level, I put the rad. cap back on and added more coolant via the air relief port. Once it started overflowing, I closed it up and proceeded to step # 5 in the FSM. It worked like a charm on the 1st try! I had to add a very small amount to the radiator once I got done with step #7.
Good luck!
Good luck!
Look,at the thread "coolant purge nightmare". There's one of these coolant threads maybe once a week it seems, and before you do anything, you need to use the search function and read everything you can.
whats your issue fam? i posted to get thoughts as I'm sure others have had the issue and done other things besides Nissan's SOP for how things go, like jacking the car up, or opening the bleeder valve, which isn't in the SOP. still fairly new to the site. so why don't you link me to the correct procedures then or actually help.
Rexrodriguez
Dec 23, 2015 09:20 AM
35reilly
Dec 14, 2015 09:14 PM
VRed8
Dec 4, 2015 12:13 AM
