need help!! car starts sometimes
Old Jan 2, 2016 | 04:29 PM
abe0911's Avatar
abe0911
Default need help!! car starts sometimes
Good evening
I have a 2003 350Z base manual transmission with 150xxx miles
I recently Change the spark plugs
Camshaft sensors and crankshaft after replacing the last one my Nightmare started.
The car starts sometimes . and after turning the engine off is almost imposible to re start the engine.
I try putting the original crankshaft sensor and problem still there .
I don't know what else I can do . thank you.
Old Jan 2, 2016 | 07:00 PM
venture210's Avatar
venture210
Have you checked your grounds?
Old Jan 2, 2016 | 07:01 PM
abe0911's Avatar
abe0911
I check to my knolege . was running perfect before
Old Jan 3, 2016 | 06:07 PM
13ringinheat's Avatar
13ringinheat
I had a similar thing happen. It turned out to be the IPDM. These electrical problems are soo hard to figure out. I have my car at the dealership multiple times till they figured out it was that. Good luck
Old Jan 3, 2016 | 07:36 PM
abe0911's Avatar
abe0911
Thank you for your response.
I figure it out one camshaft sensor connector was massed up . now is running .
The cEl light is one p0300 multiple misfire and a p0021 vvt
qew
Mar 21, 2016 10:02 PM
B_hoss
Drivetrain
Jan 6, 2016 09:55 AM
DEMoLITIoN
Jan 3, 2016 08:17 AM
Smokey Bear
Jan 1, 2016 07:04 PM
