Check engine light help
Old Mar 3, 2016 | 10:47 AM
Darkboy146's Avatar
Darkboy146
Default Check engine light help
My CEL came in after I pumped gas. I pump 93 made sure the gas cap was tight but that isn't the problem. Any ideas what it could be?
Old Mar 3, 2016 | 10:49 AM
Syner's Avatar
Syner
Old Mar 3, 2016 | 10:55 AM
HRMoneyPit's Avatar
HRMoneyPit
Wow
It must be your blinker fluid
Old Mar 3, 2016 | 11:06 AM
travlee's Avatar
travlee
Master
what is it with new members.... how are we supposed to know what is wrong with your car, hop in it, drive to autozone or somewhere and have the freaking codes read. jeebus
Old Mar 3, 2016 | 11:52 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
You have now entered the new driver zone dununununununununununu
Just a guess but did you top off the tank after the pump stopped pumping and continue to keep filling and filling and filling? And now your wondering what magical members can internet diagnose with the least possible info?
Hmmm ill play... Code p0460-p0463 all pertaining to fuel level sensor...
Let me know if I win a cookie
Old Mar 3, 2016 | 08:24 PM
Darkboy146's Avatar
Darkboy146
Going to autozone tomorrow to get the code thanks all for trying to help and sorry for not providing much information
Old Mar 3, 2016 | 08:26 PM
black93supra's Avatar
black93supra
Did you leave the car running while you were pumping gas??
Old Mar 3, 2016 | 08:36 PM
Darkboy146's Avatar
Darkboy146
Nono I did not
Old Mar 5, 2016 | 12:03 PM
Darkboy146's Avatar
Darkboy146
Update its error code P130
Old Mar 5, 2016 | 12:08 PM
travlee's Avatar
travlee
Master
O2 sensor bank 1 sensor 1
Old Mar 5, 2016 | 12:44 PM
dboyzalter's Avatar
dboyzalter
Upstream oxygen sensor circuit (bank1) voltage signal is constantly about 1.5 volts...
That is the sensor in the manifold... It shouldn't read above 0.9 which would mean your running a rich mixture, or 0.1 would be lean... It should fall between the 2.
35reilly
Mar 25, 2017 12:51 PM
RobPhoboS
Apr 4, 2016 02:50 AM
xpballer
Feb 13, 2016 03:41 PM
