Need info on interior temperature sensor
Old Feb 16, 2004 | 04:16 PM
Spartan1510's Avatar
Spartan1510
Default Need info on interior temperature sensor
HELP!
I believe I either have a bad interior temperature sensor, or that it was never connected from the factory.
Symptoms: Temperature dial set at 60, freezing cold air. Temperature dial set at 61 or anywhere above, hot hot hot! If I could only get room temperature ventilating air...THAT would be priceless.
Can anyone tell me where this sensor is at, or should be so that I can check it?
Thanks!
Old Feb 16, 2004 | 11:53 PM
3pointer's Avatar
3pointer
At least you get cold air at 60 (I wish mine does the samethin)... mine never (at any condition)..... it either blow out hot or warm air no matter what I do. Unless I trun the A/C on.
Old Feb 17, 2004 | 03:48 AM
mode101's Avatar
mode101
Default Re: Need info on interior temperature sensor
Originally posted by Spartan1510
HELP!
Thanks!
my 04 roadster is the same way. let us know if you take it in if they can fix it
Old Jun 5, 2013 | 11:51 AM
RawrXTC's Avatar
RawrXTC
Sorry to bring this back up from the dead, but did you ever find out what was wrong?
Old Jun 5, 2013 | 12:07 PM
Syner's Avatar
Syner
^Why don't you look at one of the other threads you posted in? The guy gave you an answer already.
Old Jun 6, 2013 | 03:38 PM
RawrXTC's Avatar
RawrXTC
Just did, I posted in all the threads to make sure I get an answer eventually.
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tochigi_236
Sep 27, 2015 03:40 PM
