350z keeps dying on me?!
Old Jan 24, 2017 | 03:50 PM
Nickz_33's Avatar
Nickz_33
Default 350z keeps dying on me?!
My car keeps dying on me and throws the code P0345 which is camshaft sensor bank 2 and i changed both my camshaft sensors and I changed the crankshaft sensor and its still throwing that code and dying on me do you guys have any idea what it might be? Also rpms idle really low around 500 and sometimes lower
Old Jan 24, 2017 | 04:03 PM
travlee's Avatar
travlee
Master
reset the ecu. did you do cheap aftermarket sensors or oem?
Old Jan 24, 2017 | 04:06 PM
Nickz_33's Avatar
Nickz_33
i bought the sensors from orielys for like 43 bucks and installed them my self I reset the ecu after and the next morning it has the same problems should I taken it to the dealer to check it out?
Old Jan 24, 2017 | 04:11 PM
travlee's Avatar
travlee
Master
when it comes to sensors, i always replace with oem... just me. if i remember correctly they are left and right specific. did you make sure they went in right sides?
Old Jan 24, 2017 | 04:16 PM
Nickz_33's Avatar
Nickz_33
yea there's a left a right one they look different I made sure they went on the right sides and I think your right with changing them with OEM sensors
Old Feb 1, 2017 | 12:15 PM
mxrcdude's Avatar
mxrcdude
If the sensor isn't the issue, then the part is likely the issue. If it throws a bank 2 sensor code, no need to change both sensors. If swapping bank 2 doesn't help, you may have another issue (like AVCS not functioning properly). Did you check the connectors for continuity? May have a break in the wire.
Old Feb 1, 2017 | 02:12 PM
RobPhoboS's Avatar
RobPhoboS
I just had my car cut out because of cheap ebay sensors here in the UK
The old ones are fine so are going back in, money return time.
