Clutch peddle is really stiff
Ok guys so a few days ago my clutch lost all pressure so i figured it might be the slave cylinder because i had a problem bleeding it when i put a stage 3 clutch in about a year ago but a few days ago it lost all pressure in the peddle so replaced slave cylinder and after bleeding it it got really stiff so stiff it takes both feet to push it to the floor and it want go in gear does anyone have a i deal what this could be.
350Z/370Z Tech Moderator
I'd suspect you have a clutch in which the stock hydraulics can't keep up with and something in that portion of the system has finally failed.
You will likely need to go to more performance oriented hydraulic system such as Tilton or Wilwood that are more resilient to the increased pressure needed to actuate a high sprung PP.
OR....
Bent clutch fork or pivot due to the high spring load caused by, again, such a high sprung clutch plate.
Ok so like i said before i got to use both leg to push it all the way to the floor or to even move the pedal i bled it about 5 to 6 times its a 2003 350z grand touring also if im not pushing on this clutch pedal after i build pressure up if i let it set for even 1 second it loses all pressure
This is a shot in the dark, but if there's no fluid exchange from the master cylinder to the slave cylinder, that could cause a hard clutch pedal. Are you sure that you properly connected the master cylinder to your new slave cylinder?..
