side impact airbags
Old Oct 26, 2017 | 09:35 AM
Nashe's Avatar
Nashe
Default side impact airbags
I was in an accident couple months ago and I finally got my car fixed up (almost). The accident was an impact on the passenger side, so only the passenger curtain airbag and passenger seat airbag to the side deployed. I want to fix the airbag light, so I'm guessing I'll have to replace those. Would it be replacing the: passenger curtain and whole new passenger seat (since the airbag is inside and it rips the seat), side impact crash sensor, and resetting the airbag module to factory settings?
Old Oct 30, 2017 | 06:20 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Yeah, you have to replace the damaged components first before the SRS light will go off. Then after that, you may still have to perform the airbag module reset procedure here.. https://www.google.com/search?ei=mi7....0.TUukgFMGdFc
..If the reset doesn't work, you'll then have to take it to the dealer or whoever has Consult II to read the Diagnostic Codes.
Old Oct 30, 2017 | 05:38 PM
bealljk's Avatar
bealljk
I'm not certain bc I've never done this on a Z but the old man popped his airbags and the module needed replaced (meaning one-time use only) wouldnt surprise me if that's the case on the Z ...
