Plzz help code p0507:"(
Old Nov 15, 2017 | 11:20 PM
Zurg350Hr's Avatar
Zurg350Hr
Unhappy Plzz help code p0507:"(
hey so im new too the 350z but i know my way around it since i previously owned a G35 coupe. anyways the other on my way home my service light turned on, i was driving by a Orilleys and stopped by to get it read to me. it was one code that was P0507 idle control valve. theres no difference in power that i notice, the service light turns off after a few more stops i made before getting home ( turned off my car twice at the stops) and stayed off. the next day i was driving about 15 miles away and nearly getting to where i needed to go the light turns on again this time it stayed on all day, so the next day which is today after i got out of work and the light was still on so i had to get gas and filled up my tank with 91 at my local shell i go to turn my car on and its gone its not on atm and ill keep update but anyone know whats going on im still a noob and id like some help thanks!
Old Nov 16, 2017 | 04:22 AM
travlee's Avatar
travlee
Master
do the the idle air relearn procedure
Originally Posted by DavesZ#3
From the FSM:
DTC P0507 ISC SYSTEM PFP:23781
Description ABS009IU
NOTE:
If DTC P0507 is displayed with other DTC, first perform the trouble diagnosis for the other DTC.
The ECM controls the engine idle speed to a specified level through the fine adjustment of the air, which is let
into the intake manifold, by operating the electric throttle control actuator. The operating of the throttle valve is
varied to allow for optimum control of the engine idling speed. The crankshaft position sensor (POS) detects
the actual engine speed and sends a signal to the ECM.
The ECM controls the electric throttle control actuator so that the engine speed coincides with the target value
memorized in the ECM. The target engine speed is the lowest speed at which the engine can operate steadily.
The optimum value stored in the ECM is determined by taking into consideration various engine conditions,
such as during warming up, deceleration, and engine load (air conditioner, power steering and cooling fan
operation, etc.).
DTC No. / Trouble diagnosis name / DTC detecting condition / Possible cause
P0507
0507
Idle speed control system
RPM higher than
expected
The idle speed is more than the target idle
speed by 200 rpm or more.
 Electric throttle control actuator
 Intake air leak
 PCV system
One thing they recommend is trying the Idle Air Volume Learning procedure:
Idle Air Volume Learning ABS009AU
DESCRIPTION
Idle Air Volume Learning is an operation to learn the idle air volume that keeps each engine within the specific
range. It must be performed under any of the following conditions:
 Each time electric throttle control actuator or ECM is replaced.
 Idle speed or ignition timing is out of specification.
PREPARATION
Before performing Idle Air Volume Learning, make sure that all of the following conditions are satisfied.
Learning will be cancelled if any of the following conditions are missed for even a moment.
 Battery voltage: More than 12.9V (At idle)
 Engine coolant temperature: 70 - 100°C (158 - 212°F)
 Park/neutral position (PNP) switch: ON
 Electric load switch: OFF
(Air conditioner, headlamp, rear window defogger)
On vehicles equipped with daytime light systems, if the parking brake is applied before the engine
is started, the headlamp will not be illuminated.
 Steering wheel: Neutral (Straight-ahead position)
 Vehicle speed: Stopped
 Transmission: Warmed-up
For A/T models with CONSULT-II, drive vehicle until “ATF TEMP SE 1” in “DATA MONITOR” mode of “A/
T” system indicates less than 0.9V.
For A/T models without CONSULT-II and M/T models, drive vehicle for 10 minutes.
Accelerator Pedal Released Position Learning ABS009AS
DESCRIPTION
Accelerator Pedal Released Position Learning is an operation to learn the fully released position of the accelerator
pedal by monitoring the accelerator pedal position sensor output signal. It must be performed each time
harness connector of accelerator pedal position sensor or ECM is disconnected.
OPERATION PROCEDURE
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch ON and wait at least 2 seconds.
3. Turn ignition switch OFF and wait at least 10 seconds.
4. Turn ignition switch ON and wait at least 2 seconds.
5. Turn ignition switch OFF and wait at least 10 seconds.
Throttle Valve Closed Position Learning ABS009AT
DESCRIPTION
Throttle Valve Closed Position Learning is an operation to learn the fully closed position of the throttle valve by
monitoring the throttle position sensor output signal. It must be performed each time harness connector of
electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
2. Turn ignition switch ON.
Make sure that throttle valve moves during above 10 seconds by confirming the operating sound.
Old Nov 16, 2017 | 07:52 AM
Zurg350Hr's Avatar
Zurg350Hr
I’m going to try it I’ll keep you updated
