fuel injector pressure damper
Old Nov 29, 2017 | 07:58 AM
Mikegconigs's Avatar
Mikegconigs
Default fuel injector pressure damper
So I looked under my hood and I noticed that the rubber around the fuel injector pressure damper chord was damaged. It looked as if somthing had made a clean slice and hitting it at angel that didnkt break the underneath chord. Also the tag underneath a cap that is to the left of the chord hasa cut in it aswell. Im posting to see if anyone hs hd this probelm before and if it maybe that that it is rubbing against somthing. I will add a picture of it to see what I mean.
Old Nov 29, 2017 | 08:48 AM
iideadeyeii's Avatar
iideadeyeii
That's mice teeth marks.
/end thread
Old Nov 29, 2017 | 09:42 AM
Mikegconigs
What do you mean? Lol i dont see how mice could get under the hood to eat at rubber
Old Nov 29, 2017 | 09:46 AM
iideadeyeii
/end thread
^^ Agreed ^^
Old Nov 29, 2017 | 09:48 AM
Mikegconigs
You agree that it cant be mice or are u saying u agree that it is mice?
Old Nov 29, 2017 | 11:19 AM
zakmartin's Avatar
zakmartin
It's mice. Throw a mothball or two under the hood and they'll go away.
Old Nov 29, 2017 | 11:43 AM
Mikegconigs
Where should I put the mothballs under the hood
Old Nov 29, 2017 | 12:28 PM
zakmartin's Avatar
zakmartin
Just get a little mesh bag from the crafts store, dump a mothball or two in it and zip-tie it somewhere out of the way in the engine bay (not near the fresh air vent or the inside of your car will smell like a urinal cake). The mice can smell those from 20 feet away and will avoid getting anywhere near them.
I've used this trick on more than a few farm trucks I've worked on with great success.
EDIT:
These should work:
https://www.amazon.com/Enoz-Original-Moth-*****-Each/dp/B017HZB7XE/ref=sr_1_2?ie=UTF8&qid=1511991059&sr=8-2&keywords=mothballs+for+rodents https://www.amazon.com/Enoz-Original-Moth-*****-Each/dp/B017HZB7XE/ref=sr_1_2?ie=UTF8&qid=1511991059&sr=8-2&keywords=mothballs+for+rodents
Old Nov 29, 2017 | 01:53 PM
Mikegconigs
I bought these and i set up four of them in each corner under the hood. One on the battery cover and brake fluid cover and two on eachsides of the front fender. I figure thats good for now and tomorrow ill try to put in some permanent ones
Old Nov 29, 2017 | 01:57 PM
Mikegconigs
Also how should i go about repairing it is the only option to replace the whole hose. Its not leaking as you can see its just the outter rubber but if it’s possible i might try to cut off all the ripped rubber and put new rubber on top but i dont know how i could get some rubber to exactly match it
Old Nov 29, 2017 | 03:53 PM
zakmartin's Avatar
zakmartin
If you're worried about the way it looks, then yeah, just replace the part. Otherwise, just tape it up if it's only the foam rubber insulation that's damaged. Keep an eye on it for the first few days for leaks.
Old Nov 30, 2017 | 05:07 AM
Atreyu'z 350's Avatar
Atreyu'z 350
/end thread
Chr!st. Good call... Just cut the hose HERE(in red) and slip it back over.
Old Nov 30, 2017 | 08:21 AM
zakmartin's Avatar
zakmartin
DOH! I can't believe I missed something THAT obvious
Old Nov 30, 2017 | 08:35 AM
yosip1115's Avatar
yosip1115
It will require a significant amount of press-fit force to stretch that nylon line back over the barb. I've done it with a modified calk gun and a brake flare clamp. I wouldn't bother with it. Like you said earlier it's just the protective rubber coating. They didn't eat the nylon
38 bux on ebay if you really want to fix this aesthetic imperfection.
https://www.ebay.com/itm/07-09-nissa...!US!-1&vxp=mtr
Old Nov 30, 2017 | 09:22 AM
zakmartin's Avatar
zakmartin
Stupid mice.
Old Nov 30, 2017 | 11:29 AM
Atreyu'z 350
Hmmm.. I'm gonna have to check this out when I get to my car...
Old Nov 30, 2017 | 01:15 PM
Mikegconigs
Thank you all i just cleaned spot and threw some electrical tape over it. Im prally just gunna get it replaced later.
Old Nov 30, 2017 | 02:42 PM
Atreyu'z 350
Yup. I stand corrected. Yosip and zak were right.
