2003 350z no spark
Old Apr 27, 2020 | 08:29 PM
Kaden Hartmann's Avatar
Kaden Hartmann
Default 2003 350z no spark
My 350z won't start, I've been trying for like 3 weeks and nothing has worked. While I was driving the check engine light came on and then shortly after that while I was stopped at a light it started shaking so I pulled over and shut it off. After that it wouldn't start again.
​The fuel pump wasn't making a sound so I ordered a new one but it still wouldn't start after I put it in.
while trying to start it I noticed ignition coil #1 getting really hot, I burnt up a couple before I ended up removing the engine wiring harness and checking for shorts, I found some and fixed them and the coils don't seem to get hot any
​​​​​​more.
A code reader said camshaft or crankshaft sensor so I ordered those and put them in today, still no luck starting it.
I had some coolant leaking out the overflow because I overfilled it a bit.
Nats light doesn't stay on with the key in
It doesn't seem to be getting spark I took a coil out and put it near a grounded part of the engine and nothing
I'm in need of some suggestions kindof at a loss here. Might try re doing the ipdm connectors seems to sometimes have an intermittent no prime or crank I have fixed by pushing on the connectors
ladi.in.black.
May 30, 2016 04:52 AM
Reece350z
Feb 2, 2016 05:54 AM
Shift2win
Aug 9, 2007 12:48 PM
